This is a bug fix release that includes a security update for our Graylog Operations (formerly Enterprise) and Security customers using OIDC support with Google. If you are not using OIDC support for Google, or if you are running Graylog Open Source or a version prior to Graylog 4.2,  you DO NOT need to upgrade to this version.
The new release includes the ability to set the hd authentication parameter on the OIDC Authentication pages to restrict access to members of your G Suite domain. You must set this parameter to restrict access.
If you are running self-managed, publicly available Graylog instances, we strongly recommend you upgrade your Graylog instance and set this parameter. However, everyone using OIDC support with Google should take this extra step as a security precaution.
Many thanks to our community for reporting issues and contributing fixes.
DOWNLOAD LINKS
Tarballs (manual installation):
GRAYLOG FORWARDER
Tarball (manual installation):
OS Packages
Docker image:
  • Docker Hub
  • docker pull graylog/graylog-forwarder:4.8-1
GRAYLOG ENTERPRISE 4.2.12
Released: 2022-08-09
Enterprise
Added
OPERATIONS INTEGRATIONS PLUGIN
No changes since 4.3
GRAYLOG 4.2.12
CORE
INTEGRATIONS PLUGIN
CHANGELOGS
Let us know what you’d like to have included in our GitHub issue tracker.
