Announcing Graylog Illuminate v7.0.6
Release Date: May 8th, 2026
KNOWN ISSUES
  • Illuminate: Deprecation and eventual removal of some stream categories (3575)
    • Stream categories will now be assigned based on GIM Categories from associated log streams
    • Deprecated categories to be removed in 8.0.0: webserver, firewall, network_traffic, windows_logs, linux, system, compliance, endpoint, hids
ADDED
  • Symantec ProxySG: Security Core support (3430)
    • GIM categorization for all TCP and UDP proxy event types with expanded vendor_event_action support
    • Changed http_category to use proper schema field http_uri_category
    • Updated extraction pattern for vendor_event_action
  • OSSEC HIDS: Security Core support and extended alert categorization (3439)
    • Authentication, network connection, IAM, audit, and extended detection categorization
  • AWS Security Hub: Security Core support (3437)
    • Refined GuardDuty network detection categorization
    • Fixed Macie S3 field extraction
  • WatchGuard Firebox: Security Core support (3427)
    • Network connection, detection, authentication, service, and audit categorization
  • Google Workspace: Security Core support (3419)
    • Added GIM codes to Login and Token logs
    • Added event_outcome lookup (success/failure) derived from vendor_event_name for Login and Token logs
    • Added application_name field to Google Workspace logs
  • Okta: Security Core support (3421)
    • Detection event processing, logoff event categorization, and token revoke tracking
    • Updated Okta event catalog to cover all current event types
  • Stormshield Firewall: Security Core support (3428)
    • GIM 120200 (network connection initiated) for filter, connection, and alarm events
    • GIM 300001 (network_detection) for alarm events
    • GIM 130000 (email sent) for smtp events; GIM 180300 (http proxied) for web events
    • GIM 100000 (authentication.logon) for xvpn “SSL tunnel created”; GIM 102500 (logoff) for “SSL tunnel destroyed”
    • Updated field mapping for source_port, destination_port, source_nat_port, vendor_data_pri, and event_duration
  • Bind DNS: Security Core support (3390)
    • GIM event type assignments for all BIND DNS log channels: queries, query errors, security, zone transfers, dynamic updates, DNSSEC, notify, and general
    • Query error logs now separately categorize negative DNS responses (NXDOMAIN, SERVFAIL, REFUSED) from infrastructure errors
    • Added event_action and event_outcome mappings for denied and failed DNS outcomes
  • ProFTPD Server: Security Core support (3438)
    • Authentication, network connection, and file operation categorization
  • Packetbeat: Security Core support (3425)
    • Fixed typo in spelling of spotlight file
  • GitLab: Security Core support (3422)
    • Authentication, IAM, HTTP communication, audit policy, and vulnerability detection categorization
  • FortiWeb: Security Core support (3436)
    • HTTP communication, authentication, service, audit, and detection categorization
  • Symantec Endpoint Security: Security Core support (3431)
    • File Activity (subtype 8003) → FILE GIM category (file.default)
    • Registry Key Activity (8005) and Registry Value Activity (8006) → REGISTRY GIM category
    • Host Network Activity (8007) → NETWORK GIM category (network.default)
    • System Activity 8001 events without Process Launch context → PROCESS GIM category (process.default)
  • Symantec EDR: Security Core support (3429)
    • GIM categorization for Process Launch, Process Termination, User Session expired, and Intrusion Prevention log types
    • Fixed application_name field mapping for audit and diagnostic log types
    • Refactored MITRE array deduplication and registry path construction
FIXED
  • Cisco ASA: source_reference no longer set to static sentinel for management-plane auth/identity events (3300)
    • Event codes 113006, 113007, 502101, 502102 previously hardcoded source_reference to “SOURCE_NOT_DEFINED“
    • This caused false positives in detections grouping by source_reference (e.g., password-spray rules)
    • The static value has been removed
  • Security Core: Fixed query string for some detection_query instances missing a trailing colon that caused indexing errors (3843)
  • Check Point Firewall: Fixed event_action mapping and added missing action values (3635)
    • Fixed event_action being set to EVENT_ACTION_NOT_DEFINED when action was present in the log
    • Added missing action mappings for VPN and authentication events (Key Install, Log In, Log Out)
    • Fixed Detect action incorrectly mapped to “allowed” instead of “detected”
    • Added user identity field extraction for VPN and Identity Awareness events
  • Mimecast: Removed pipeline rule that rewrote the message field since the input doesn’t support writing the full_message field (3689)
  • Fortigate: DNS logs now categorized by specific name resolution subcategory when vendor_eventtype is present (3685)
    • dns-query events → GIM 140000 (dns request); dns-response events → GIM 140200 (dns answer)
    • Previously all DNS events defaulted to name resolution default (GIM 149999)
  • Mimecast: Fixed pipeline errors and warnings caused by unmapped vendor event types (3793)
    • vendor_event_action could previously be set to the literal string “null” for unknown event types
    • A missing field guard produced runtime warnings for directory sync events
  • Security Core: Fixed spelling of sigma_rule_tag in the ‘Successful RDP Logon from External Source’ event definition (3820)
  • Cisco ISE: Fixed negative UTC offset parsing and incorrect wifi_bssid/wifi_ssid field assignment (14180)
    • Fixed base field extraction regex to accept negative UTC offsets (e.g., -04:00)
    • Split single wifi SSID extraction rule into two rules to handle all vendor_SSID value formats
CHANGED
  • 1Password: Expanded field extraction, GIM authentication and IAM categorization, and Security Core support (3408)
    • Expanded schema field extraction across sign_in_attempts, audit_events, and item_usages
    • Added GIM authentication categorization for sign-in events by outcome
    • Added IAM categorization for six audit_events identity lifecycle actions
    • Added source_user_* actor fields for audit_events; destination_reference for sign-in events
    • Replaced broad vendor_subtype GIM lookup with purpose-built categorization rules
  • Metricbeat: Enabled GIM code assignment and expanded metric normalization coverage (3440)
    • Enabled processing for 5 additional metric types
    • Expanded field normalization coverage
  • Check Point Firewall: Refined Security Core detection categorization (3393)
    • Refined SmartDefense/IPS detection events from generic detection to specific IDS detection categorization
  • Microsoft IIS: Security Core support and HTTPERR log parsing (3418)
    • Added HTTPERR (HTTP.sys error) log parsing
    • GIM 180200 (http communication) categorization for all log types
    • Added Security Core enforcement fields
  • Mimecast: Security Core support with GIM categorization across authentication, IAM, audit, and messaging events (3417)
    • Login, MFA, and access policy events → authentication events
    • User account and group management → IAM events
    • Policy and configuration changes → audit events
    • Archive message views and searches → messaging events
    • Added normalized event_action and event_outcome fields for all event types
  • AWS VPC (Kinesis): Refined GIM event type code from network connection to flow record (3435)
  • Symantec Endpoint Protection: Security Core support with refined GIM categorization (3423)
    • AV and SONAR detections → host_detection
    • Browser/IPS events → ids_detection
    • Firewall packet and traffic events → network connection
    • SEPM policy changes → audit.policy events
  • F5 BIG-IP: Security Core support with GIM enforcement fixes and new event parsing (3433)
    • Expanded GIM coverage and reference field derivation for network enforcement
    • Added mcpd service event categorization and LTM connection event parsing
  • Sophos Firewall: Security Core support with refined GIM categorization (3416)
    • Refined GIM categorization for IPS detection events and HTTP content filtering
    • Fixed detection events incorrectly defaulting to event_action=allowed
  • Cisco 350: Security Core support (3434)
    • Authentication, service, audit, and detection categorization for Cisco Business 350 Series switches
  • Illuminate: Updated stream categories assigned (3575)
  • Bitdefender Telemetry: Added missing event mappings and DocGen documentation (3412)
    • Added missing file_access event categorization
    • Expanded event action mappings and fixed several processing bugs
  • Zeek: Security Core support with GIM code refinements and event normalization (3424)
    • NTLM authentication events → credential validation (100500)
    • SSL, DCE/RPC, NTP, and weird events → network.default (129999) instead of uncategorized (000000)
    • Added event_action normalization for conn and HTTP log types
    • Added event_outcome normalization for conn and DNS log types
    • Removed trailing spaces from rename field destinations; converted test files to raw codec
  • Illuminate: Pack title format updated (3602)
    • “Illuminate {VERSION}:” prefix removed from processing and spotlight pack titles
    • A date-based version (year, month, day of update) is now appended to each pack title
  • Juniper SRX: Security Core support (3413)
    • Authentication, network, and detection categorization; updated pack title format
  • Caddy Web Server: Security Core support (3414)
    • Both access and error logs categorized as GIM 180200 (http communication) with network_protocol=http
  • Bitdefender GravityZone: Refined Security Core categorization for new-incident events (3399)
    • EDR new-incident events now categorized as detection.host_detection (GIM 301000) on both push (CEF) and on-prem syslog transports
    • Replaces prior detection.default (309999) assignment
    • GravityZone incidents now surface alongside anti-exploit and advanced-threat-control detections in Security Core dashboards
Let us know what you’d like to have included in our GitHub issue tracker.
