Announcing Graylog Illuminate v7.0.5
Release Date: April 7th, 2026
ADDED
  • Microsoft Defender for Endpoint: Added Security Core support. (3398)
    ○ Added GIM event type code 300000 (ids_detection / detection.network_detection) to all Microsoft Defender for Endpoint alert events, replacing detection.default (309999). Required fields are set via first_non_null.
  • PfSense: Added new fields and features to support Security Core (3378)
    ○ Added the field network_protocol with the value http to traffic logs
    ○ Improved Squid proxy support
    ○ Changed GIM code from 129999 to 180300 (web proxy)
    ○ Added event_action and network_transport lookups
    ○ Renamed fields for better GIM alignment
    ○ Added http_request_path extraction
    ○ Improved Snort, sshguard, and Suricata support
    ○ Changed GIM code from 309999 to 300001 (network detection)
    ○ Added sshguard alert as a recognized event type
    ○ Added alert and reference fields
    ○ Fixed quoted field extraction issues
    ○ Improved DNS support and named (BIND) compatibility
    ○ Added Blocking → blocked mapping
  • Sysmon: Added user_name and user_domain parsing for event_code 13. (3336)
  • Snort: Changed GIM code from 309999 to 300001 to better support Security Core (3426)
  • Linux: Added Security Core support. (3377)
    ○ Added GIM categorization across authentication, IAM, service, and process
    ○ Improved event_action mapping
    ○ Fixed SSH, PAM, login, cron, and systemd assignments
  • Missing Field(s) – Microsoft Windows Security 4624 (1620)
    ○ Added Elevated Token check
    ○ Added Special Logon categorization
    ○ Assigned privileged user_category
  • Sysmon: Added user_name and user_domain parsing for event_code 10. (3339)
  • Apache HTTPD: Added network_protocol field with value http for access logs. (3376)
  • Cisco Meraki: Added Security Core support, VPN parsing, and expanded GIM categorization. (3403)
    ○ Refined authentication, flow, and detection event mappings
    ○ Expanded lookup coverage
  • Apache Tomcat: Added Security Core support. (3380)
    ○ Added service lifecycle GIM codes
    ○ Added network_protocol field
  • Illuminate Core: Updated static accounts table (3305)
    ○ Added more default accounts
  • Microsoft Defender Antivirus: Added Security Core support and ASR processing. (3385)
    ○ Added service lifecycle mappings
    ○ Added ASR and tamper protection handling
    ○ Added malware and real-time protection coverage
  • Squid Proxy Content Pack (3243)
    ○ Added documentation and description
  • Microsoft AppLocker: Added Security Core support and WDAC processing. (3401)
    ○ Added detection categorization
    ○ Added WDAC event support
  • Illuminate: Add Security Core content (3586)
  • Ubiquiti UniFi: Added Security Core support and CEF parsing. (3402)
    ○ Added firewall and IPS detection mapping
  • Windows Security: Updates to support Security Core. (3375)
    ○ Expanded event coverage and field extraction
    ○ Improved IAM and RDP enrichment
  • Cisco Umbrella: Added Security Core support for blocked events. (3407)
    ○ Added DNS and proxy detection categorization
  • PowerShell: Added GIM categorization for Winlogbeat and NXLog. (3384)
    ○ Added lookup tables and pipeline rules
    ○ Fixed NXLog processing
  • Sophos Central: Added Security Core support and categorization. (3411)
    ○ Added event group mappings
  • Microsoft DHCP: Added Security Core support. (3400)
    ○ Expanded DHCP event categorization
  • Sysmon: Updates to support Security Core. (3381)
    ○ Added IP/MAC list handling
  • NetFlow: Added Security Core support. (3394)
    ○ Added network connection categorization
  • Palo Alto 11: Added support for UDP input. (3227)
  • Cisco ASA: Added Security Core support. (3388)
    ○ Refined GIM mappings and normalization
  • Cisco IOS: Updates to support Security Core. (3391)
    ○ Added new event parsing
  • Cisco ASA: Added support for additional event codes. (3282)
  • Mimecast: Added parsing for archive_search logs. (3104)
  • PostgreSQL Content Pack (3298)
    ○ Added PostgreSQL support
  • AWS Security Lake: Added Security Core support and OCSF v1.1.0 support. (3392)
    ○ Added categorization and finding support
  • Microsoft 365: Added Security Core support. (3395)
    ○ Added credential validation mapping
  • Cisco ISE: Added Security Core support and fixes. (3396)
    ○ Updated authentication mappings
  • Added network_intrusion stream category (3352)
  • NGINX Web Server: Added Security Core support. (3389)
    ○ Added service error categorization
  • Palo Alto 11x: Added Security Core support. (3397)
    ○ Added GlobalProtect authentication mapping
FIXED
  • Stream category network_traffic not assigned (3338)
  • Added dns stream category (3358)
    ○ Applied across multiple packs
  • user_type:computer underscore issue (3097)
  • Illuminate, Bind inconsistencies (3370)
    ○ Added query error extraction
  • Packetbeat multiple IP handling (3155)
    ○ Fixed list vs single-value handling
CHANGED
  • Microsoft 365: Updated pack name (3157)
  • Core: Updated MITRE ATT&CK to v18 (3233)
    ○ Removed ICS and Mobile
  • Curated Alerts: Reduced false positives (2524)
  • CrowdStrike Falcon: Refined GIM mappings (3410)
  • SonicWall NGFW: Improved GIM mappings and parsing (3415)
  • Fortigate: Updated event_id mapping (567)
  • Windows DNS Server: Improved categorization (3383)
  • Windows: Updated field mapping (3281)
  • PowerShell: Updated pack name (3293)
  • HAProxy: Refined GIM mappings (3405)
  • Check Point: Updated pack name (3290)
  • Microsoft AppLocker: Updated pack name (3292)
  • Security Core: Fixed group/user normalization (3252)
  • Cloudflare: Improved GIM mapping and actions (3406)
  • FortiGate: Expanded Security Core compatibility (3379)
  • Carbon Black Defense: Refined mappings (3409)
  • Removed spotlight metadata (2833)
  • Linux Auditbeat: Improved coverage (3382)
  • Caddy: Updated pack name (3294)
  • AWS VPC: Updated pack name (3289)
  • Linux Auditd: Updated pipelines (3386)
  • Bind DNS: Improved parsing (3250)
  • Windows: Updated privilege lookup (3369)
Let us know what you’d like to have included in our GitHub issue tracker.
