Announcing Graylog Illuminate v7.0.4
Release Date: March 17th, 2026
FIXED
- SonicWall NGFW: Fixed VPN login over-counting and missing VPN user list after SonicOS 7.3.1 upgrade (3279)
- VPN login events were being over-counted on dashboards following the SonicOS 7.3.1 firmware upgrade. Event 139 (SSL VPN zone session setup) was incorrectly classified as an authentication logon event alongside event 1080 (SSL VPN user login), causing both to be counted per login. Event 139 is now classified as an access notice (GIM code 101001) consistent with event 141, so only the primary login event is counted.
- VPN dashboard user lists were blank after the SonicOS 7.3.1 upgrade because the firmware changed the SSL VPN session type from
sslvpnctoGMS. All VPN dashboard queries have been updated to includeGMSin theapplication_namefilter alongside the existingvpnc,sslvpnc,l2tpc, andPortalvalues. - Fixed typos in Security Services event category labels (events 1270-1274).
- Event 1681 (IKEv2 Packet sent/received) was missing from the event lookup table, causing
gim_event_type_codeto be empty for these events. It is now mapped to the VPN IKEv2 event group.
- Apache HTTPD: Fixed parsing failure when username is a UPN (contains @). (3447)
CHANGED
- Postfix: Relay-forwarded log support, field rename, and GIM categorization (3460)
- Relay-forwarded logs (e.g. from amavis or SpamAssassin) are now correctly identified and parsed. Previously these were silently dropped because the relay sets
application_nametomailinstead ofpostfix. - The field
vendor_daemonhas been renamed toservice_nameto better reflect its meaning (the Postfix sub-process that generated the message, e.g.smtpd,smtp,cleanup). - GIM event type codes are now assigned to all Postfix messages: email delivery (130000), rejection (131000), quarantine (131500), network connections (120200/120300), SASL authentication (100500), and service lifecycle events (210000/210100/211000).
- Network fields
destination_reference,source_reference,destination_port,source_port, andnetwork_transportare now populated for connection events (connect, TLS, disconnect, timeout) to satisfy GIM field enforcement. - Authentication events now populate
source_referencefrom the authenticating server IP and setuser_nameto avoid GIM field enforcement errors.
Let us know what you’d like to have included in our GitHub issue tracker.
