Building a Process for Investigating Deployment Failures In the CI/CD Pipeline
Building a Process for Investigating Deployment Failures In the CICD Pipeline
When a pipe bursts in your house, the resulting flood is only one symptom of a larger plumbing problem. Until you find that hidden pipe in your wall, you’re going to mop and clean for days. Ultimately, the cost of the burst pipe includes more than just the physical material. It includes the drying, the plumber’s labor, the water damage to floors and walls, the mold remediation if it goes undetected for too long, and the disruption to everyday life while repairs are underway.
CI/CD deployment failures work the same way. Engineering teams have to stop work on the core product to investigate the root cause. When the pipeline is down, the team is unable to ship features, provide fixes to users, and work on projects that meet business goals.
By understanding the most common causes of CI/CD deployment failures and how to build an efficient investigation process, teams can identify and resolve issues faster.
What is a CI/CD pipeline failure?
Continuous Integration and Continuous Deployment (CI/CD) is an automated system that takes code from a developer’s commit and moves it through a series of steps that can include:
  • Source control: A developer pushes code, triggering the pipeline.
  • Build: The pipeline compiles and packages the source code into a deployable artifact.
  • Test: Automated tests validate the code across unit, integration, and end-to-end checks.
  • Security scanning: Automated tools scan dependencies and code for known vulnerabilities.
  • Staging deployment: The build deploys to a pre-production environment for final validation.
  • Production deployment: The validated build goes live for real users.
A CI/CD pipeline failure occurs when the process breaks during any of the stages. Different failures lead to various outcomes like:
  • Build failure: Pipeline is unable to compile or package code.
  • Test failure: The code is fine but fails a quality check.
  • Deployment failure: After building and testing, an error occurs when pushing the code to the production environment.
Why do deployment failures matter?
When a pipeline fails, it can impact customers, internal teams, and critical systems. Some common outcomes include:
  • Blocked teams: No one can ship code until after resolving the failure.
  • Delayed releases: Features, fixes, and hotfixes remain in queue.
  • Production downtime: Failures in the live environment create outages for users.
  • Wasted engineering time: Teams spend time investigating failures rather than focusing on core product updates.
  • Compounding bottlenecks: A staging failure slows the entire release cycle.
What are some common CI/CD deployment failure types?
By understanding the most common pipeline failures, DevOps teams can fix issues faster.
Environment and Configuration Mismatches
The pipeline runs in a different environment than the one the developer used to write source code. Small differences that can look like bugs include:
  • Tool versions.
  • Operating system dependencies.
  • Environment variables.
For example, a pipeline and the CI runner that executes the pipeline run on different nodes causing the build to fail and generate a module error unrelated to the actual code.
Some ways to fix this include:
  • Pinning tool and language versions explicitly in your pipeline configuration.
  • Using Infrastructure as Code (IaC) to standardize environments across staging and production.
  • Adding a pre-deployment check that compares environment variables across environments.
Dependency and Version Conflicts
Applications can rely on dozens of external packages. When a package runs a different version in different places or an update creates an incompatibility, the build can break in difficult to identify ways.
For example, if a teammate submits a pull request that updates an external package, the version in the dependency file no longer matches what the pipeline tries to install, breaking the build.
  • Specifying the exact software versions in your pipeline configuration so every environment uses the same ones.
  • Using Infrastructure as Code (IaC) to build environments consistently rather than configuring them by hand.
  • Adding an automated check before deployment that confirms all environments are configured identically.
Secrets and Permissions Failures
A deployment requires credentials to access a production environment, like cloud providers, databases, or third-party services. Missing, expired, or misconfigured credentials can cause the failure, and an error message may not list credentials as the issue.
For example, a cloud provider deployment may silently fail if someone rotated the access key for security purposes but never updated the pipeline.
  • Storing credentials in a dedicated secrets manager rather than pasting them directly into pipeline configuration files.
  • Adding a credential and access permission validation step before the deployment actually runs.
  • Updating the pipeline part when rotating or updating credentials rather than waiting.
Flaky Tests
Automated testing can give inconsistent results, often related to the test environment’s stability. Developers typically re-run the CI/CD pipelines to make them pass, but this fails to fix the underlying issue.
For example, a test checking a connection to a shared database can pass nine out of ten times, but fail by timing out when another process is using the database.
  • Looking for patterns when failures occur, like during periods of high activity, pointing to a resource conflict rather than a source code problem
  • Setting up automatic retries as a short-term measure while you dig into the root cause.
  • Tracking how often each test fails over time to see if the test automation is flaky or broken.
Infrastructure Failures
When the underlying infrastructure running the pipeline is broken, the failures can surface as build or deployment errors. Identifying the failure becomes time-consuming as engineers may look in the wrong location.
For example, if jobs start failing simultaneously across multiple CI/CD pipelines, the error could be that the server running them ran out of disk space.
  • Setting up automated health checks on the servers running CI/CD pipelines, and configuring them to restart automatically when something goes wrong.
  • Monitoring servers for warning signs like low disk space, high memory usage, and expired security certificates.
  • Restarting the CI/CD pipeline tool that executes jobs before digging through logs.
Building a Deployment Failure Investigation Process
Without a repeatable root cause investigation process, deployment failures become chaotic and time-consuming.
Centralize Logs
When pipeline failures occur, having information scattered across multiple systems increases overall investigation times. Centralizing logs gives teams a single source of truth for searching, filtering, and correlating events across the entire pipeline.
Some types of logs to collect include:
  • CI/CD tool logs: Step-by-step outputs from tools like GitHub Actions, GitLab CI, Jenkins, or CircleCI.
  • Application logs: Data from the application being built and deployed, including errors and warnings generated at runtime.
  • Infrastructure logs: Information from servers, containers, or cloud resources where the pipeline runs.
  • Dependency and build tool logs: Outputs from package managers and build systems that surface version conflicts or missing packages.
  • Security and access logs: Events related to credential usage, permission checks, and authentication events that reveal secrets or permissions failures.
  • Test runner logs: Detailed output from automated test frameworks that goes beyond the pass/fail summary shown in the pipeline UI.
Confirm the Failure’s Scope
The failure’s scope determines where to investigate first. When the team has aggregated pipeline data, they can answer the question faster. Some questions to ask include:
  • Is this affecting one pipeline or all of them?
  • Is the failure consistent or intermittent?
  • Check the pipeline platform’s public status page before doing anything else
Identify the Failed Stage
Build, test, and deployment failures point to different root causes. Most pipeline platforms show the failed step, but sometimes the failures are ambiguous or span multiple stages. Aggregating and correlating logs from all stages can reduce investigation times. When investigating failures, teams should consider the different stages involved:
  • Build failures: Investigating environment configuration, software versions, and dependencies.
  • Test failures: Reviewing test stability, resource availability, and external connections.
  • Deployment failures: Looking at credentials, permissions, and infrastructure health.
Build a Hypothesis
After identifying the failed stages, teams should create a hypothesis to focus the investigation. Often, the first error shown is not the original trigger.
When building a hypothesis, start by matching the failure stage to the most relevant log sources:
  • Build failure: Start with CI/CD tool logs and dependency logs for missing packages, version conflicts, or environment mismatches.
  • Test failure: Start with test runner logs and infrastructure logs for resource contention, timeouts, or connectivity issues with external services
  • Deployment failure: Start with security and access logs and infrastructure logs for expired credentials, permission errors, or server-level issues
  • Failure affecting all CI/CD pipelines at once: Start with infrastructure logs for an issue with a shared resource like a server or network component.
  • Intermittent failure with no obvious cause: Cross-reference CI/CD tool logs and application logs across multiple runs for patterns in timing, load, or external dependencies.
Isolate What Changed
Most deployment failures trace back to something that recently changed. Often, teams have to correlate a failure’s timing against recent activity, like:
  • Code changes.
  • Dependency updates.
  • Configuration edits.
  • Credential rotations.
Some common locations to identify changes include:
  • A pull request merged just before the failure.
  • A dependency version upgrade.
  • A configuration edit.
  • A rotated or expired credential.
  • An infrastructure change.
Reproduce Before Fix
By running the steam steps the pipeline runs in the same environment, teams can fix the issues once instead of pushing changes and waiting for the pipeline to cycle. Additionally, this step confirms the diagnosis before any changes are made, which matters when multiple people are investigating the same failure simultaneously.
Fix One Variable at a Time
Changing multiple things at the same time makes identifying the actual resolution difficult. Further, it means that the team might accidentally reintroduce the same failure later.
Some best practices for this stage include:
  • Documenting each change as it’s made, like leaving creating a ticket as a record.
  • Running the pipeline after each change to generate signals about whether the hypothesis was correct.
  • Reverting changes that fail to fix the issue to prevent introducing new failures.
  • Keeping a list of issues that did not cause the failure.
Set Up Alerts
Alerts help reduce downtime and outages. Building high-fidelity alerts separates out the noise so that teams can detect a deployment failure before a user reports it.
Some best practices for building meaningful alerts include:
  • Alert on specific failure conditions: Focus on alerts that fire when a deployment stage fails after a successful test stage tells the team exactly where to look.
  • Tier alerts by severity: Route minor issues to a log or a low-priority channel, and reserve high-urgency notifications for failures that affect real users
  • Include context in the alert itself: Include which pipeline, stage, and environment should be in the notification for faster investigations.
  • Set thresholds: Reduce noise by alerting when the failure rate crosses a defined threshold surfaces a real problem rather than for every single failed test.
  • Review and tune alerts regularly: Reconfigure alerts when no one acts on them to ensure consistent response and investigation.
Graylog: Faster Investigations to Reduce Downtime
Graylog enables engineering and DevOps teams to investigate deployment failures faster by bringing logs from every stage of the CI/CD pipeline into a single, searchable platform. Rather than hunting through disconnected outputs from multiple tools, teams can search, filter, and correlate log data in real time, moving from alert to root cause in minutes instead of hours. With configurable alerting, teams get notified the moment something goes wrong, with enough context to start investigating immediately. By centralizing pipeline logs and building smarter alerts, organizations reduce mean time to resolution, minimize the impact of deployment failures, and spend less time firefighting and more time shipping.
