This is a bug-fix release improving the functionality of Graylog. Please read on for detailed descriptions of each bug fix.
Many thanks to the Graylog Community for reporting issues and contributing fixes.
DOWNLOAD LINKS
Tarballs (manual installation):
GRAYLOG FORWARDER
Tarball (manual installation):
OS Packages
Docker image:
  • Docker Hub
  • docker pull graylog/graylog-forwarder:4.10-1
GRAYLOG OPERATIONS 4.3.8
Released: 2022-10-05
Changed
  • Reduced log level for noisy log messages in the Office365 input.
Fixed
  • Fixed problem with archive retention configuration form.
  • Fixed file handle leak in HTTP-based lookup table adapters.
GRAYLOG 4.3.8
Changed
  • Changed the default value for the elasticsearch_index_optimization_jobs config option to 10 to resolve an issue where index optimization could block message ingestion.
Fixed
  • Fixed validation issue with dashboards.
  • Fixed running Graylog on FIPS-enabled Red Hat Enterprise Linux.
  • Fixed search query validation for invalid regular expression queries.
  • Fixed –dump-default-config server command.
CHANGELOGS
Let us know what you’d like to have included in our GitHub issue tracker.
