Announcing Graylog v4.1 Beta 2
We are excited to announce the Graylog v4.1 Beta 2. The testing phase is underway. Thank you for all your great feedback. We still need your help, so please keep testing.
DETAILS ABOUT THE BETA
  • The v4.1 beta will run for the next 10 days to two weeks.
  • In addition to this build, we will have an additional beta and an RC.
  • There are no prerequisites for the v4.1 beta.
  • Please install the v4.1 beta separately from your production Graylog instance.
  • Please report bugs and any other issues in our GitHub issue tracker.
  • Thank you for testing!
WHAT’S IN THE BETA?
Graylog v4.1 includes a number of new features for Open Source, Enterprise, and Cloud, as well as new Data Adapters, improvements to existing Enterprise Data Adapters, UI Enhancements, and more.
DOWNLOAD LINKS
GRAYLOG CORE
Tarballs (manual installation):
GRAYLOG FORWARDER
In the upcoming 4.1 release of Graylog, we are migrating the Cloud Forwarder and making it available in Graylog Enterprise. Enterprise users can configure your Forwarder to send data to Graylog Cloud or from Graylog cluster/instance to Graylog cluster/instance.
Tarball (manual installation):
OS Packages
IMPORTANT NOTES
  • We are not including OVA or AWS downloads for the beta.
  • If you’ve configured an S3 Archiving backend, you need to delete it before upgrading to the next Beta.
  • We caution you not to install or upgrade Elasticsearch to 7.11 and later! It is not supported. If you do so, it will break your instance!
LIST OF NEW FEATURES
  • Redesign Aggregation builder
  • Log View Widget (enterprise)
  • Widget focusing
  • Redesign Search Time Range Picker
  • New export formats JSON, NDJSON, Plain Text (enterprise)
  • Highlighting rule gradient option
  • Responsiveness of dashboard tabs bar
  • Value actions on pie and bar chart
  • Parameter options select (enterprise)
  • Heatmap color scale
  • Time range info for dashboard widgets
  • LDAP/AD Data Adapter
  • Back-end REST API for Theme Customizer
  • GreyNoise basic data adapter for Open Source
  • GreyNoise enhanced data adapter for Enterprise
  • Abuse.ch URLhaus data adapter for Enterprise
  • MongoDB storage for data adapter data that used to be stored in memory
  • Back-end REST API for Custom Notifications
  • Archive support for S3
  • Okta authentication support and teams sync
