Incident Investigations
Redefining Security Incident Management
Uncover critical insights and address security incidents swiftly with Graylog's powerful new feature - Incident Investigations. Built to facilitate efficient analysis and response to security incidents, this feature is equipped with advanced search capabilities, correlation techniques, and visualization tools. These components provide an essential toolset to delve deep into your logs, allowing your security team to investigate, identify threats, and respond effectively.
HOW IT WORKS
Investigations from a Log Message: Start your investigation right from a specific log message. Graylog’s Investigations feature provides a robust search interface, allowing complex queries across vast volumes of log data. Leverage various search filters, including time ranges, event types, specific hosts or devices, and custom metadata, to focus on the most relevant log entries.
Integrating Dashboards: Visualize your log data through interactive charts, graphs, and timelines. Graylog’s Investigations feature enhances your analysis process by allowing you to spot trends, anomalies, and relationships between events effortlessly.
Alert Workflow Integration: This feature perfectly dovetails with the alert workflow, enabling you to investigate alerts triggered by real-time or historical log data. Connect alerts with investigations for a quick assessment of incidents and to gather additional evidence.
Collaboration and Case Management: Streamline your complex investigations with efficient collaboration. Use Graylog Teams to share findings and document investigation details. The Investigations feature also offers case management capabilities, allowing you to organize investigations into cases, assign tasks, and track progress.
EXAMPLES
  • Faster Threat Detection:
    Leverage the powerful search capabilities and correlation techniques of Graylog’s Investigations to identify security threats quickly, reducing investigation time, and allowing for swift incident response.
  • Improved Incident Response:
    Gain a comprehensive understanding of security incidents through advanced visualization tools. Prioritize critical threats and mitigate risks promptly.
  • Enhanced Forensic Analysis:
    Trace the timeline of events, identify potential attack vectors, and understand the impact of security incidents using the Investigations feature for a detailed forensic analysis.
  • Streamlined Collaboration:
    Foster effective teamwork and knowledge sharing with Investigations’ collaboration and case management capabilities.
FREQUENTLY ASKED QUESTIONS
  • WHAT DOES AN IT SECURITY INCIDENT INCLUDE?
    IT security incidents refer to any event, intentional or not, that threatens the integrity, confidentiality, or availability of information systems. It can range from phishing attacks, malware infections, unauthorized access, to data breaches.
  • WHAT ARE THE SEVEN PHASES OF SECURITY INCIDENT RESPONSE?
    The seven phases are Preparation, Identification, Containment, Eradication, Recovery, Lessons Learned, and Prevention. Each phase plays a crucial role in managing and mitigating security incidents.
  • WHAT IS THE IT SECURITY INCIDENT MANAGEMENT PROCESS?
    The incident management process involves a series of steps aimed at responding to and managing security incidents. These steps include identifying, categorizing, responding, recovering, documenting, and analyzing incidents to prevent recurrence.
  • WHAT IS THE INCIDENT INVESTIGATION IN CYBERSECURITY?
    Incident investigation in cybersecurity involves the process of investigating security incidents or breaches. It aims to understand the nature and extent of the incident, identify the root cause, assess the damage, collect evidence, and devise an appropriate response.
Experience the power of Graylog’s Incident Investigations feature today and elevate your security response to the next level.
We've Got You Covered
Windows
Linux
Unix
JSON, CSV, TXT
Storage Mgmt
Custom Apps
Change Mgmt
Switches
Firewalls
DNS
Routers
DBMS
Commercial Apps
