Announcing Graylog Illuminate v6.2
Announcing Graylog Illuminate 6.2
Released: 2024-02-06
Added
  • MS365: Extract host_name from AzureActiveDirectory (EntraID) Endpoint message metadata (2599)
  • Illuminate Core: Add Internal/Enterprise Networks process/feature (2584)
    • This change adds a lookup named “core_networks” to Illuminate core.  Illuminate customers can customize the adapter “core_networks_adapter”, adding a CIDR-notation IP range and category values. Illuminate will detect when source_ip/destination_ip/host_ip matches these CIDR ranges and add a related category field, source_category/destination_category/host_category, with the values provided in the lookup.
  • MS365: Extract email metadata from Exchange events (2577)
    • Extract Email metadata from Exchange events, including email subject and email parent folder path.
  • Windows Security: Added parsing for Linked Logon ID (user_linked_session_id) – event 4624 (1890)
  • Sonicwall: Added and changed parsing for some fields (2556)
    • Added parsing for destination_nat_ip, source_nat_ip, destination_nat_port and source_nat_port. Renamed vendor_referer to http_referrer and vendor_icmpCode to network_icmp_code_number. Added support for IPv6.
  • Linux: Added parsing for UFW logs (2623)
  • Windows Security: Add support for Windows Event ID 4696 and 4703 (2053)
  • Linux: Added parsing for IPTable logs (2634)
  • Core: Added lookup table that maps query_record_type to query_record_type_code. (2478)
  • Sonicwall: Added support for the new detection category in the dashboard (2553)
  • AppLocker: Windows AppLocker Content Pack (2607)
    • Windows AppLocker enables administrators to control which applications and files users can run,  including executables, dynamic-link libraries (DLLs), scripts, installers and packaged apps.
  • MS365: Added parsing for Exchange Item Group auditing activity. (2601)
    • This activity details information when multiple mailbox items are accessed or modified as part of one consolidated action and includes e-mail attachment extraction.
  • MS365: Added parsing for Teams privacy setting changes to a team. (2586)
  • Curated Alerts: Adding Windows Threat Campaigns – Sigma Rules (2547)
    • A collection of Sigma rules selected from TruKno’s Threat Detection Marketplace and curated by the Illuminate team.
  • Sonicwall: Added and changed categorization for some event codes. (2548)
    • The following event_codes are now categorized: 14, 36, 97, 263, 355, 356, 524, 526, 1573. The following event_code has been changed: 1226 is now 129999 and not 180200, 120000.
Fixed
  • Cloudflare: Possible indexing errors with vendor_edge_response_compression_ratio data type (2613)
  • Windows Security: Fixed the typos for ProcessCreation and AADInternals. (2578)
  • Updated stream routing rules with match pass logic where applicable. (2612)
    • Stream routing rules should be set to match pass to take advantage of the _skip_default_gl_routing_ field when set.
  • Curated Alerts: Make Webserver and Linux pack visible (2620)
    • The bundle now contains the Webserver and Linux Curated Alert packs.
Changed
  • Sonicwall: Lowered license utilization (2550)
    • The message field is now the vendor msg field to avoid data duplication. The following fields are now deleted if they are zero: destination_bytes_sent, destination_packets_sent, source_bytes_sent, source_packets_sent.
  • MS365: Update Exchange parent folder item processing to extract individual fields (2580)
  • Checkpoint FW: Properly named count related metric widget(s) in spotlight. (2527)
  • Core: Updated description for the core-sigma-field-map_adapter data adapter so it accurately reflects the required key and value. (2568)
  • Curated Alerts: Added a gl- prefix to the SIGMA IDs (2637)
  • Meraki: Properly named count related metric widget(s) in spotlight. (2530)
  • MS365: Removed event_log_name field. (2600)
    • Removed the event_log_name field which is better represented by vendor_record_type_code and the lookup enhancements that come with it.
Let us know what you’d like to have included in our GitHub issue tracker.
