Announcing Graylog Illuminate v3.1
The following Illuminate Spotlight content packs have been updated since Illuminate 3.0.2:
  • Graylog Illuminate 3.1.0:Cisco ASA Spotlight
  • Graylog Illuminate 3.1.0:Core Spotlight
  • Graylog Illuminate 3.1.0:Fortinet Fortigate Spotlight
  • Graylog Illuminate 3.1.0:SonicWall NGFW Spotlight
  • Graylog Illuminate 3.1.0:Watchguard Firebox Spotlight
  • Illuminate indices field mapping changes (#424):
  • The default mapping type for strings is now “keyword”
  • This will take effect after the index rotation that follows the installation of Illuminate 3.1
  • There will be no change to the Graylog schema field mappings and content but it may impact some non-schema fields
Please report bugs and any other issues in our GitHub issue tracker. Thank you!
GRAYLOG ILLUMINATE 3.1
Released: 2023-01-06
Fixes
  • Cisco ASA fixes
  • Improved ICMP data handling (#820)
  • Fixed alert severity not being properly mapped (#819)
  • Fixed field mappings for NAT events (#813)
  • Fixed field extraction for multiple events (#821, #569, #902, #915, #935, #957)
  • Extracted event outcome from some messages (#540)
  • Support extracting numeric protocol values (#900)
  • Improved port number/service name extraction (#901)
  • Assigned correct categorization for 302013, 302015, 302016 events (#940)
  • Added support for mapping vendor_event_outcome to event_outcome (#958)
  • Core: GIM enforcement for Alert messages is incorrect
  • Windows: Fields winlogbeat_winlog_event_data_param1 may cause incorrect dynamic mapping assignment (#884)
  • Fortigate: time calculation can lead to indexing error (#1024)
  • NXLog support: Keywords field contains numeric value that can overflow mapping type “long” (#987)
  • Core: Dashboard widget not using correct sorting (#1042)
  • Sonicwall NGFW: Dashboard widget uses incorrect metric (#1040)
Enhancements
  • Added Stormshield processing and Spotlight (#802)
  • Cisco ASA improvements
  • Added support for extracting FQDN fields (#896)
  • Simplified processing of Cisco events by using lookup-based parsing (#556)
  • Added processing for new events (#898, #918, #641, #936, #937, #938, #939, #942, #944, #947, #948, #952, #954, #959, #960, #964, #965, #966, #967, #968, #971, #990, #993, #994, #1012, #1013, #1023)
  • Add processing for DHCP events (#963, #966)
  • Watchguard: Added DHCP event processing support (#956, #1018)
  • Meraki: Added DHCP event processing support (#1029)
  • Fortigate: Added DHCP event processing support (#1021)
  • GIM Enforcement: Added DHCP event enforcement (#972)
Known Issues
  • Auditbeat cannot process events with multiple values assigned to “vendor_event_action” (#622)
Let us know what you’d like to have included in our GitHub issue tracker.
